TaskPaper 3.7.5 Preview (305)
  • Fixed problems styling and updating searchbar
  • Fixed keyboard focus problem when closing searchbar
  • Added warning that imported reminders are removed from Reminders.app
  • Added warning when trying to work with Reminders.app without access granted
Note If you are on macOS 10.13 TaskPaper’s in app Software Update might fail in the download phase. (you can manually download from link in those post). Please let me know (either way) about this. I’m seeing the error, but am wondering if some people are not seeing it… I can’t make sense of why it’s happening :slight_smile:
Issue Tracker
Download
Just tried it, worked fine for me. (Installed 10.3.1 yesterday.)
Did you install with auto-update or directly using the above download?
Via the auto-update. But I believe it was from an earlier version (2-3 updates old), not the most recent prior version.
