Added
- Header and footer printing options to print panel.
- Track expanded/collapsed state in extended file attribute.
- Edit > Copy Displayed (Option-Command-C) for only displayed items.
- Added a
ShowPreviewBadge
defaults key to hide “Prev” badge in TaskPaper’s preview version.
Changed
- Tag autocompletions are now case insensitive.
- Tag autocompletions only popup when editing at end of tag.
- Require that both
and)
be escaped with\
when used in tag values. - Move “Saved Searches” to top of toolbar search field popup.
- Apply tag and similar commands only effect displayed items, even when selection includes collapsed or filtered items.
- Items that are hidden with no visible ancestor are no longer deleted or copied even when the selection overlaps them.
Fixed
- Items > Format As to work when item is a project with trailing tags.
- Document name (instead of always “Untitled”) now displays in printed header.
Themes
Renamed “display” text style attribute (used in base.less) to “content”. If your custom theme targets the “display” attribute anywhere you should change it to target “content” for version 3.2.
Scripting API
Added API for accessing Outlines and OutlineEditors:
Outline.getOutlines()
OutlineEditor.getOutlineEditors()
OutlineEditor.getOutlineEditorForOutline(outline)
Added additional API for selected items:
selectedItems
– All items intersecting the selection. -
displayedSelectedItems
– Displayed items intersecting the selection. -
displayedAncestorSelectedItems
– All displayed items or items with a displayed ancestor intersecting the selection.
Renamed private API item.bodyDisplayString
to item.bodyContentString
and documented it as public API.
Script debug process change
Previously you accessed TaskPaper’s internal scripting context through Window > Show Script Debugger. That menu is removed, now you should:
- Open Safari
- Open TaskPaper
- Ensure Safari’s “Develop” menu is showing.
- Choose Safari > Develop > Computer > TaskPaper > index.html
And you show see a debug window for TaskPaper’s JavaScript context. This debug window has the added benefit of now working! It should break on any debugger
statements in your script.
Changes since the last Preview release
- Added more scripting API for accessing Outlines and OutlineEditors
- Added Edit > Copy Displayed
- Changed Items that are hidden with no visible ancestor are no longer deleted or copied even when the selection overlaps them. (Needs lots of testing!)
