is it possible to move the searches above the projects on the sidebar (in general move these around)
thanks
thanks
No, but you can configure what searches and tags show up (in additions to the ones that automatically show up because they are in your document. See the “configuration” files described here:
https://guide.taskpaper.com/using-taskpaper/using-the-sidebar.html
