Hey, searches are finding other searches for me in 3.5 (237). Is this new? I’d prefer searches to be excluded.
This has always been the behavior I think. You can tack except @search
to the end of your search to remove it.
But I think the better solution for many cases is to define searches outside the document. Not possible yet, but will be for version 3.5 eventually. Then you won’t need to worry about defining searches in each document, and you wont have problems such as finding your searches.
