FT Crashing in High Sierra
Hi all,
I’m encountering frequent crashing of Folding Text in macOS High Sierra. It usually happens when I start FT, especially when double clicking an FT document. The crashes typically happen when FT has started and starts reading the document (as it appears). Then you get the dialog window macOS presents with Ignore/Report/Restart buttons.
I’ll update this when I have more details to add. Will there be an update of Folding Text soon?
I am seeing a lot of crashes also. Sometimes when a document has been open for a while and nothing is being done in FT.
Would like to know also if there will be an update and of course if others are seeing it.
Folding Text Version 2.2 (770)
Hi Guys and Gals – I had same issue with crashes of recent. Solved this by temporarily deactivating all plugins and putting back in one at a time until I identified 2 that were causing crash.
I didn’t check yet if there were updated versions of these but these were my culprits:
  • jmk_panel.ftplugin
  • sexytime-theme.ftplugin (I do like the look of this but don’t understand why it can’t be just a replacement user.less file anyway)
YMMV but I’d suggest giving it a try first before blaming the app itself:
  • From App’s File menu>Open Application Folder
  • I made a Plugins (disabled) folder and moved everything out of Plugins folder to start.
Some new app love would be welcome too! But I understand life get’s in the way :slight_smile:
Updating my previous post. I have no plug-ins installed. FT keeps consistently crashing when I open a document from the Finder (mostly) of from the menu in FT. Often when I open docs I see only the top paragraphs and after 10 seconds or so I see the rest of the text; while waiting for the rest of the text I see the spinning beachball. That also happens (sometimes) in other apps. Once FT is up and running for more than ±10 seconds I have no crashes.
I suspect this is connected to the APFS file system in High Sierra. And hopefully there will be an update. FoldingText is one of the gems in my app-toolbox…
I’m seeing the same behavior since the 10.13.4 update. I don’t have any plugins installed in FT and never saw crashes previously.
Hey, guys.
Environment:
  • Mac OS X 10.13 (17A405).
  • FoldingText. Version 2.2 (770).
Procedure step:
  1. run FoldingText 2 and edit, save file;
  2. put your MacBook to sleep;
  3. wake up your MacBook from sleep mode and try to resume working with the file.
Expected results: FoldingText gives you the ability to see the file, make and save changes.
Actual results: FoldingText is closed and needs to be re-run to use.
Part of the crash report:
Process:               FoldingText [291]
Path:                  /Applications/FoldingText.app/Contents/MacOS/FoldingText
Identifier:            FoldingText
Version:               2.2 (770)
Code Type:             X86-64 (Native)
Parent Process:        ??? [1]
Responsible:           FoldingText [291]
User ID:               501
Date/Time:             2018-06-05 10:20:45.564 +0300
OS Version:            Mac OS X 10.13 (17A405)
Report Version:        12
Anonymous UUID:        5ADFD3AF-654A-A71B-CF9C-F4F92DECD201
Sleep/Wake UUID:       F724A07A-2642-4AFC-86C1-29F11C9A90B3
Time Awake Since Boot: 14000 seconds
Time Since Wake:       340 seconds
System Integrity Protection: enabled
Crashed Thread:        0  Dispatch queue: com.apple.main-thread
Exception Type:        EXC_BREAKPOINT (SIGTRAP)
Exception Codes:       0x0000000000000002, 0x0000000000000000
Exception Note:        EXC_CORPSE_NOTIFY
Termination Signal:    Trace/BPT trap: 5
Termination Reason:    Namespace SIGNAL, Code 0x5
Terminating Process:   exc handler [0]
Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
Thread 1:: com.apple.NSURLConnectionLoader
0   libsystem_kernel.dylib        	0x00007fff527a0e76 mach_msg_trap + 10
1   libsystem_kernel.dylib        	0x00007fff527a0390 mach_msg + 60
2   com.apple.CoreFoundation      	0x00007fff2b0f6475 __CFRunLoopServiceMachPort + 341
3   com.apple.CoreFoundation      	0x00007fff2b0f57c7 __CFRunLoopRun + 1783
4   com.apple.CoreFoundation      	0x00007fff2b0f4e43 CFRunLoopRunSpecific + 483
5   com.apple.CFNetwork           	0x00007fff2a06e432 +[NSURLConnection(Loader) _resourceLoadLoop:] + 357
6   com.apple.Foundation          	0x00007fff2d1af6d8 __NSThread__start__ + 1197
7   libsystem_pthread.dylib       	0x00007fff528e46c1 _pthread_body + 340
8   libsystem_pthread.dylib       	0x00007fff528e456d _pthread_start + 377
9   libsystem_pthread.dylib       	0x00007fff528e3c5d thread_start + 13
Thread 2:
0   libsystem_kernel.dylib        	0x00007fff527a9e7e __psynch_cvwait + 10
1   libsystem_pthread.dylib       	0x00007fff528e5662 _pthread_cond_wait + 732
2   libc++.1.dylib                	0x00007fff50699d43 std::__1::condition_variable::__do_timed_wait(std::__1::unique_lock<std::__1::mutex>&, std::__1::chrono::time_point<std::__1::chrono::system_clock, std::__1::chrono::duration<long long, std::__1::ratio<1l, 1000000000l> > >) + 93
3   com.apple.JavaScriptCore      	0x00007fff2ebaacd5 std::__1::cv_status std::__1::condition_variable::wait_until<std::__1::chrono::steady_clock, std::__1::chrono::duration<long long, std::__1::ratio<1l, 1000000000l> > >(std::__1::unique_lock<std::__1::mutex>&, std::__1::chrono::time_point<std::__1::chrono::steady_clock, std::__1::chrono::duration<long long, std::__1::ratio<1l, 1000000000l> > > const&) + 117
4   com.apple.JavaScriptCore      	0x00007fff2ebaabc0 std::__1::cv_status std::__1::condition_variable_any::wait_until<std::__1::unique_lock<bmalloc::Mutex>, std::__1::chrono::steady_clock, std::__1::chrono::duration<long long, std::__1::ratio<1l, 1000000000l> > >(std::__1::unique_lock<bmalloc::Mutex>&, std::__1::chrono::time_point<std::__1::chrono::steady_clock, std::__1::chrono::duration<long long, std::__1::ratio<1l, 1000000000l> > > const&) + 96
5   com.apple.JavaScriptCore      	0x00007fff2ebaaa59 bmalloc::AsyncTask<bmalloc::Heap, void (bmalloc::Heap::*)()>::threadRunLoop() + 233
6   com.apple.JavaScriptCore      	0x00007fff2ebaad28 void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (*)(bmalloc::AsyncTask<bmalloc::Heap, void (bmalloc::Heap::*)()>*), bmalloc::AsyncTask<bmalloc::Heap, void (bmalloc::Heap::*)()>*> >(void*) + 40
Thread 3:: com.apple.CFStream.LegacyThread
5   com.apple.CoreFoundation      	0x00007fff2b1e0f15 _legacyStreamRunLoop_workThread + 277
6   libsystem_pthread.dylib       	0x00007fff528e46c1 _pthread_body + 340
7   libsystem_pthread.dylib       	0x00007fff528e456d _pthread_start + 377
8   libsystem_pthread.dylib       	0x00007fff528e3c5d thread_start + 13
Thread 4:: IndexedDatabase Server
2   com.apple.JavaScriptCore      	0x00007fff2e0e9d5f WTF::ThreadCondition::timedWait(WTF::Mutex&, double) + 63
3   com.apple.JavaScriptCore      	0x00007fff2eb920a8 WTF::ParkingLot::parkConditionallyImpl(void const*, WTF::ScopedLambda<bool ()> const&, WTF::ScopedLambda<void ()> const&, WTF::TimeWithDynamicClockType const&) + 2600
4   com.apple.WebCore             	0x00007fff383705da bool WTF::ConditionBase::waitUntil<WTF::Lock>(WTF::Lock&, WTF::TimeWithDynamicClockType const&) + 154
5   com.apple.WebCore             	0x00007fff3881929f WTF::CrossThreadQueue<WTF::CrossThreadTask>::waitForMessage() + 95
6   com.apple.WebCore             	0x00007fff388191ce WebCore::IDBServer::IDBServer::databaseRunLoop() + 110
7   com.apple.JavaScriptCore      	0x00007fff2e0e23ef WTF::threadEntryPoint(void*) + 111
8   com.apple.JavaScriptCore      	0x00007fff2e0e233a WTF::wtfThreadEntryPoint(void*) + 74
9   libsystem_pthread.dylib       	0x00007fff528e46c1 _pthread_body + 340
10  libsystem_pthread.dylib       	0x00007fff528e456d _pthread_start + 377
11  libsystem_pthread.dylib       	0x00007fff528e3c5d thread_start + 13
Thread 5:: WebCore: AsyncFileStream
5   com.apple.WebCore             	0x00007fff38370e7f std::__1::unique_ptr<WTF::Function<void ()>, std::__1::default_delete<WTF::Function<void ()> > > WTF::MessageQueue<WTF::Function<void ()> >::waitForMessageFilteredWithTimeout<WTF::MessageQueue<WTF::Function<void ()> >::waitForMessage()::'lambda'(WTF::Function<void ()> const&)>(WTF::MessageQueueWaitResult&, WTF::MessageQueue<WTF::Function<void ()> >::waitForMessage()::'lambda'(WTF::Function<void ()> const&)&&, WTF::WallTime) + 127
6   com.apple.WebCore             	0x00007fff38370dbd WTF::Function<void ()>::CallableWrapper<WebCore::callOnFileThread(WTF::Function<void ()>&&)::$_6::operator()() const::'lambda'()>::call() + 93
Thread 6:: com.apple.NSEventThread
5   com.apple.AppKit              	0x00007fff2884f1f1 _NSEventThread + 184
Thread 7:
0   libsystem_kernel.dylib        	0x00007fff527aa6da __workq_kernreturn + 10
1   libsystem_pthread.dylib       	0x00007fff528e426f _pthread_wqthread + 1552
2   libsystem_pthread.dylib       	0x00007fff528e3c4d start_wqthread + 13
Thread 8:: WTF::AutomaticThread
2   com.apple.JavaScriptCore      	0x00007fff2e0e9d9a WTF::ThreadCondition::timedWait(WTF::Mutex&, double) + 122
4   com.apple.JavaScriptCore      	0x00007fff2e6db70a bool WTF::ConditionBase::waitUntil<WTF::Lock>(WTF::Lock&, WTF::TimeWithDynamicClockType const&) + 154
5   com.apple.JavaScriptCore      	0x00007fff2eb80505 WTF::Function<void ()>::CallableWrapper<WTF::AutomaticThread::start(WTF::AbstractLocker const&)::$_0>::call() + 165
6   com.apple.JavaScriptCore      	0x00007fff2e0e23ef WTF::threadEntryPoint(void*) + 111
7   com.apple.JavaScriptCore      	0x00007fff2e0e233a WTF::wtfThreadEntryPoint(void*) + 74
8   libsystem_pthread.dylib       	0x00007fff528e46c1 _pthread_body + 340
9   libsystem_pthread.dylib       	0x00007fff528e456d _pthread_start + 377
10  libsystem_pthread.dylib       	0x00007fff528e3c5d thread_start + 13
Thread 9:
1   libsystem_pthread.dylib       	0x00007fff528e406a _pthread_wqthread + 1035
Thread 10:: WTF::AutomaticThread
Thread 11:
Thread 12:: WTF::AutomaticThread
Thread 13:: WTF::AutomaticThread
Thread 14:: WTF::AutomaticThread
Thread 15:
0   libsystem_pthread.dylib       	0x00007fff528e3c40 start_wqthread + 0
Thread 0 crashed with X86 Thread State (64-bit):
  rax: 0x00007fff85e3ed50  rbx: 0x000000010e9d8d10  rcx: 0x8000000000009800  rdx: 0x0000000000009800
  rdi: 0x000000010e9d8d10  rsi: 0x0000000000009646  rbp: 0x00007ffee4016a70  rsp: 0x00007ffee4016a40
   r8: 0x000000000000007f   r9: 0x00007fff871ebf40  r10: 0x00000000e345f2a7  r11: 0xffffffffffffffff
  r12: 0x0000000000000001  r13: 0x000000010f91c6c0  r14: 0x000000010eb00030  r15: 0x0000000000000000
  rip: 0x00007fff2e980b2e  rfl: 0x0000000000000202  cr2: 0x0000604000658ff8
Logical CPU:     0
Error Code:      0x00000000
Trap Number:     3
Binary Images:
       0x10bbe3000 -        0x10bc8cff7 +com.foldingtext.paddle.FoldingText (2.2 - 770) <2F7C557A-A8D0-3AFB-91B4-3696C42E00BC> /Applications/FoldingText.app/Contents/MacOS/FoldingText
       0x10bcb3000 -        0x10bd0fff7 +com.paddle.Paddle (2.4.3 - 2.4.3) <B1298E64-0D6D-3BEE-A220-87101E17F861> /Applications/FoldingText.app/Contents/Frameworks/Paddle.framework/Versions/A/Paddle
       0x10bd43000 -        0x10bd7efff +org.sparkle-project.Sparkle (1.13.1 git-2afc553 - 1.13.1) <40414915-A48C-3DBB-AACB-5C20BAAE6DA6>
External Modification Summary:
  Calls made by other processes targeting this process:
    task_for_pid: 27
    thread_create: 0
    thread_set_state: 0
  Calls made by this process:
    task_for_pid: 0
    thread_create: 0
    thread_set_state: 0
  Calls made by all processes on this machine:
    task_for_pid: 9103
    thread_create: 0
    thread_set_state: 0
VM Region Summary:
ReadOnly portion of Libraries: Total=443.9M resident=0K(0%) swapped_out_or_unallocated=443.9M(100%)
Writable regions: Total=1.5G written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=1.5G(100%)
                                  VIRTUAL   REGION
REGION TYPE                          SIZE    COUNT (non-coalesced)
Accelerate framework                 512K        5
Activity Tracing                     256K        2
CG backing stores                    516K        4
CG image                             196K       29
CoreAnimation                       7576K       45
CoreGraphics                           8K        2
CoreImage                            240K       54
CoreUI image data                   3228K       29
CoreUI image file                    328K        6
Foundation                           800K        4
Image IO                              32K        3
JS JIT generated code              256.0M        5
JS JIT generated code (reserved)   768.0M        2         reserved VM address space (unallocated)
Kernel Alloc Once                      8K        2
MALLOC                             227.2M       64
MALLOC guard page                     64K       16
Memory Tag 242                        12K        2
Memory Tag 251                        84K        4
SQLite page cache                     64K        2
STACK GUARD                         56.1M       17
Stack                               15.6M       17
VM_ALLOCATE                          232K       23
WebKit Malloc                      263.2M       30
__DATA                              38.2M      341
__FONT_DATA                            4K        2
__GLSLBUILTINS                      2588K        2
__LINKEDIT                         189.0M       11
__TEXT                             254.9M      345
__UNICODE                            556K        2
mapped file                         86.5M       80
shared memory                        812K       15
TOTAL                                2.1G     1134
TOTAL, minus reserved VM space       1.4G     1134
Model: MacBookAir7,2, BootROM MBA71.0171.B00, 2 processors, Intel Core i5, 1.8 GHz, 8 GB, SMC 2.27f2
Graphics: Intel HD Graphics 6000, Intel HD Graphics 6000, Built-In
Memory Module: BANK 0/DIMM0, 4 GB, DDR3, 1600 MHz, 0x02FE, -
Memory Module: BANK 1/DIMM0, 4 GB, DDR3, 1600 MHz, 0x02FE, -
AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x117), Broadcom BCM43xx 1.0 (7.77.37.0.1a1)
Bluetooth: Version 6.0.0f7, 3 services, 27 devices, 1 incoming serial ports
Network Service: Wi-Fi, AirPort, en0
Serial ATA Device: APPLE SSD SM0128G, 121.33 GB
USB Device: USB 3.0 Bus
USB Device: BRCM20702 Hub
USB Device: Bluetooth USB Host Controller
Thunderbolt Bus: MacBook Air, Apple Inc., 27.2
