Version 3.5 Preview (258) running on MacBook macOS 10.11.6 (15G31)
Everytime I select Archive @done items or use the keyboard shortcut, the app quits.
Otherwise a beautiful version.
Cheers,
Stephen Hryncewicz
Cheers,
Stephen Hryncewicz
Thanks, fixed for the next release.
Brilliant! Thanks.
whew! thanks for the quick fix.
Hello!
Grievous bug is saved in a copy of the application.
There is no difference which way I use. The app crashing when trying to back up all the tasks with @done tag by pressing a hotkey or a menu.
The problem was in the 290 and 291 versions preserved.
Please, fix it.
Thanks
Can you describe how to reproduce the crash, seems to work ok in my testing. Problem must be related to specific setup… please let me know exact steps to reproduce the crash in a new document. Thanks!
I tried many times to repeat the bug, but I could not. The error was in the archive part of the file. I deleted it and it solved my problem.
The following causes a crash in version 3.8.1 when I select Archive @done items or use the keyboard shortcut (I can’t put tabs here so add two on the appropriate line) :
– no indentation @done(2018-11-09)
Archive:
– indent twice @done(2018-11-08)
– no indentation @done(2018-11-06)
I can reproduce this crash.
FYI: you can show tabs on the forum if you use the “preformatted text” option (select the text and click </> or type ⌘⇧C):
Archive:
Thanks, I can reproduce this cash too. I’ll try to get a fix out soon.
Thanks again for easy to reproduce result, I’ve fixed this for next release. Will post preview soon.
