Release Notes
App
- New Icon, thanks @sdw!
- New Code, rewrote native layer in Swift 3
- New Requirements, now requires OS X 10.11 or later
Sidebar
- Added Projects, Searches, and Tags sections
- Ability to Show/Hide sidebar sections
- Ability to Expand/Collapse Individual Projects
- Double-click on project in sidebar to “hoist”, show only it’s descendants
- Tags configuration file, allowing you to choose tags shown/hidden in the sidebar
- Searches configuration file, allowing you to choose searches shown in the sidebar
- Context menu (and main menu) items for creating, editing, and deleting saved searches
- Saved searches may be embedded in current document, or saved separately
Searchbar
- Larger, can more easily display complex searches
- Only shows when active (preference to change this behavior)
- Attention getting, you should never miss the fact that a search is active (changeable in stylesheet)
- Much faster search results in large documents with complex search logic
Palettes
- New Palettes UI, faster keyboard navigation
- Replaced “Go to” popup menu’s with new palette UI
- Added “Go to Anything" Palette
- Added “Command palette" with ability to add your own script commands
- Changed keyboard shortcuts so all palettes use a form of Command-P
Tabs/Windows
- Ability to open multiple windows (or tabs on macOS 10.12) on a single document
- Added “Open in New Window” popup item for sidebar items
- Added “Open in New Tab” popup item for sidebar items (macOS 10.12)
- Reorganized menu items to better fit macOS 10.12’s “Show Tab Bar” item
Stylesheets
- Ability to switch between stylesheets
- Each window can now have a different (Window > Style) style
- Printing panel has it’s own separate stylesheet setting
- Renamed
display
span stylesheet attribute tocontent
- New options including text wrap and typewriter scrolling (see user’s guide for details)
Other
- Added Allow delete backward to un-indent items preference
- Added Preference to maintain search when select project changes
- Added Preference to maintain project when select search changes in sidebar
- Added scripting API to get all OutlineEditors associated with a given outline
- Removed many “New Document” preferences (spelling, etc), those settings now apply to all documents
- Changed direct download bundle ID to avoid conflicts with app store version
- Direct download version recognizes App Store licenses (must run App Store version once first)
- Improved folded state persistence in documents that are edited outside TaskPaper
- Improved Drawing of split cursor text insertion point
- Changed default font to system reported “user font”
- Fixed file and icon associations
Issue Tracker
