Change color of vertical "handle-lines"
Hi there,
this is my first post and been happily working and customizing taskpaper, although I can’t code :slight_smile:
But one thing I couldn’t figure out:
How can I customize the colors of vertical lines next to expanded items?
And how can I change it based on depth? (for clarity, see screenshot)
Thanks!!
Hi and welcome!
The “guide line color” is a global style right now, so you customize through the editor like this:
editor {
  guide-line-color: green;
  guide-line-width: 2;
You can change item styling based on depth using item depth attribute like this:
item[depth=1] {
  handle-color: orange;
item[depth=2] {
  handle-color: blue;
Will override above depth setting for any leaf (item with no children)
item[leaf] {
  handle-color: green;
Also, you might have already found them, but be sure to check out:
https://guide.taskpaper.com/customizing-taskpaper/creating-stylesheets.html
https://guide.taskpaper.com/reference/stylesheets/
And then a key bit in that second link is:
To see TaskPaper’s default stylesheet rules open TaskPaper.app/Content/Resources/base-stylesheet.less. This is also good general stylesheet formatting reference.
Hi Jesse,
is it by now possible to change the guide-line-color based on depth?
the command:
item[depth=1] {
only changes the handle color for collapsed items, I’d like to change handle & guide-line color for uncollapsed items.
@jessegrosjean or anyone else an idea?
I made a quick mockup, think it would be quite helpful for long indented lists.
Taskpaper - guide-line colors Taskpaper - guide-line colors
Not possible with the current system. But a better alternative may be to note the difference in depth by changing the guide color or the actual text color.
Hope this was helpful.
Yeah that’s a good idea, thank you! I’ll experiment with this.
